Not In Sync :Sync Configuration
Not In Sync
Sync Configuration
Configuration failed: Skipped because device does not support Strict Password Policy.
What I do in the access point controller is not applied to my device and not device to device, so I am having trouble managing it. I hope you can find a solution for this.
Hi @KCL_Fectory ,
Please follow these steps to successfully push the configuration:
  1. Navigate to Configuration > Advanced Features and uncheck the “Enable Strict Device Password Policy” option. Then, save the changes.
  2. Go to your respective configuration profile, update the password, and apply it to the device.
//Indra
:+1:Thank you so much problem is solve
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
