hello all its been awhile since my last post
been busier than all get out but now i have run into a major problem.
my ofdm back haul is getting very slow response from my one tower.
when i do a speed test via j perf from the tower to my data center it is in the kbits of around 300-500 kbits which sucks.
when i do the same test from data center to tower i get 4.5 megs i am a little confused i know that the backhauls are on different rx and tx freq and that i may get some interferance but i thought the ofdm does some freq hopping and up till now it has been fine.
these are 30/60 meg orthogon backhauls
MASTER
Software Version 5830-05-01 Maximum Transmit Power 24 dBm
Hardware Version D04-R08-A01 Remote Maximum Transmit Power 24 dBm
Region Code 1 Transmit Power 24.0, 22.9, 21.9, 23.0
dBm
Elapsed Time Indicator 06:16:08 Receive Power -85.6, -87.7, -97.7, -87.4
dBm
Ethernet / Internet Vector Error 4.9, -7.8, -9.5, -9.1
dB
Ethernet Link Status Up Link Loss 167.8, 158.1, 156.6, 157.7
dB
Ethernet Speed 100 Mbps Receive Data Rate 3.94, 2.37, 0.4, 2.99
Mbps
Ethernet Duplex Full Transmit Data Rate 4.98, 3.40, 0.5, 3.99
Mbps
MAC Address 00:04:56:00:1a:2b Receive Modulation Mode QPSK 1/2 (2.99 Mbps)
IP Address 10.0.10.31 Transmit Modulation Mode QPSK 2/3 (3.99 Mbps)
Subnet Mask 255.0.0.0 Available Channels 19
Gateway IP Address 10.0.0.1 Range 36.1 km
Automatic
SLAVE
Region Code 1 Transmit Power 24.0, 23.3, 23.0, 23.0
dBm
Elapsed Time Indicator 12 Days 01:01:00 Receive Power -85.2, -87.1, -162.0, -86.6
dBm
Ethernet / Internet Vector Error -2.1, -8.7, -10.2, -9.7
dB
Ethernet Link Status Up Link Loss 233.0, 157.1, 155.2, 156.2
dB
Ethernet Speed 100 Mbps Receive Data Rate 4.99, 3.42, 0.4, 3.99
Mbps
Ethernet Duplex Full Transmit Data Rate 3.94, 2.40, 0.3, 3.99
Mbps
MAC Address 00:04:56:00:1a:19 Receive Modulation Mode QPSK 2/3 (3.99 Mbps)
IP Address 10.0.10.33 Transmit Modulation Mode QPSK 2/3 (3.99 Mbps)
Automatic page
any input is appreciated.
[/img]
Your signal looks pretty low. The radios are only connected at 2.99 and 3.99 mbps which for those radios is kinda low. Maybe you got some new interference in the area. Check your spectrum.
moose is right… your modulation is 2/3 that is extremely low… either the units have moved or there is interference…
spectrum scan… realignment…
yeah i was just up the tower today and did a repoint had to move my head end back haul 20 ft over and got somewhat better results.
still really low and really noisy.
it seems that some one decided to add some floors to the hospital that is right in front of our path and i think that is what is messing things up.
regards,
