Is there a way to create omni patterns in link planner? Currently I have to add 4 ap's on a network site to simulate our Omni coverage. Thanks.
Hi Nathan,
LINKPlanner uses a 3D antenna pattern for the AP antenna to predict the performance to each SM. I am sorry but at present there isn't a way to add additional antennas for the AP into LINKPlanner. Even though the azimuth pattern of an omni antenna is relatively uniform, the elevation pattern can have a significant contribution and varies between antenna models, so there isn't a standard omni pattern that can be used.
Regards,
Rachel
