Dear Team.
let us know how we can config the on premises cnMaestro ?
how we can install cnMaestro using VM ware.?
Let us konw the steps to instll the VM ware and cnMaestro
Regards
Manoj C Adiga
Dear Team.
Regards
Manoj C Adiga
https://support.cambiumnetworks.com/files/cnmaestro/
the user guide and the quick start guide have the directions step by step getting setup.
If you are using a VM server different than shown, follow the basic steps from that vendor, its a stand disk setup. also the supported VM services are listed in these docs.
Could you configure it? Im having the same problem...
The Quick Start guide is in the Archive section (https://support.cambiumnetworks.com/files/cnmaestro/archive) -- you should use 1.2.2. It provides step-by-step instructions. We will move it back to the main page, so it is easier to locate. You need to install the 1.2.2 OVA first, and then upgrade to the 1.3.0-r7 build.
