Hi! I am relatively new in Cambium Networks, so forgive me if I ask stupid questions.
I am trying to onboard E410 AP to cnMaestro3 on Premise, but I am having problems connecting.
I have cnPilot e410 AP (latest firmware) on 192.168.100.0/24 network, and cnMaestro 3(latest version) on premise server on 192.168.200.10/24 network.
AP can ping the server and vice versa, but can’t connect to cnMaestro server.
This is what i get in logs:
021-08-24 15:30:29 8603 device-agent.c:2421:Previous state 0 new state 1
2021-08-24 15:30:29 8603 device-agent.c:2491:da_enter_state:DA_STATE_DISCOVERY
2021-08-24 15:31:46 8603 log.c:207:start_cns_logging: Send log history (10 lines)
2021-08-24 15:30:29 8603 wifi.c:424:platform_get_static_url: cns_url [ 192.168.200.10]
2021-08-24 15:30:29 8603 discover-cns.c:105:cnMaestro url = 192.168.200.10
2021-08-24 15:30:29 8603 http_parser.c:2432:get_parsed_url_details: len=5 offset=0
2021-08-24 15:30:29 8603 http_parser.c:2433:url= [https:// 192.168.200.10]
2021-08-24 15:30:29 8603 http_parser.c:2441:get_parsed_url_details: protocol=[https]
2021-08-24 15:30:29 8603 discover-cns.c:133:cnMaestro host 192.168.200.10 port 443
2021-08-24 15:30:29 8603 discover-cns.c:167:discover_cns: method 0 cns_url [ 192.168.200.10]
2021-08-24 15:30:29 8603 https-client.c:144:dev_type [Sage] sw_vers [4.2.1-r12] user_agent [cnDA/1.0 (Sage/4.2.1-r12; DA/3.36)]
2021-08-24 15:30:29 8603 https-client.c:147:build_http_get_request: cns_url [ 192.168.200.10]
2021-08-24 15:30:29 8603 https-client.c:175:build_http_get_request: No cambium_id available
2021-08-24 15:30:29 8603 wifi.c:1879:platform_get_deviceId_cookie: ENTRY
2021-08-24 15:30:29 8603 wifi.c:1932:platform_set_cns_connection_state: New Connection_state Connecting(4)
2021-08-24 15:30:29 8603 wifi.c:1967:platform_set_cns_connection_state: idle_timeout=312
2021-08-24 15:30:29 8603 https-client.c:680:Calling OpenConnection
2021-08-24 15:30:29 8603 https-client.c:269:OpenConnection: hostname [ 192.168.200.10] port [443/443]
2021-08-24 15:30:29 8603 utils.c:82:hostname is an IPv4 address
2021-08-24 15:30:29 8603 https-client.c:296:Resolving URL 192.168.200.10
2021-08-24 15:30:29 8603 https-client.c:301:Resolved 192.168.200.10 to IPv4 address
2021-08-24 15:30:29 8603 https-client.c:308:Trying connection with ip [ 192.168.200.10], ai_next (nil)
2021-08-24 15:30:29 8603 https-client.c:324:connect() Operation now in progress
2021-08-24 15:30:29 8603 https-client.c:346:connect() success
2021-08-24 15:30:29 8603 https-client.c:349:Connected socket 0 IP [192.168.103.248]
2021-08-24 15:30:29 8603 https-client.c:352:Device IP 192.168.103.248
2021-08-24 15:30:29 8603 https-client.c:686:TCP connection is successful
2021-08-24 15:30:29 8603 https-client.c:690:Create SSL context, ca certs path is /etc/ssl/certs/
2021-08-24 15:30:29 8603 https-client.c:711:Openssl connection to 192.168.200.10 : 443
2021-08-24 15:30:29 8603 https-client.c:733:SSL_ERROR_WANT_READ try again
2021-08-24 15:30:29 8603 common.c:283:Non-cambium/cloud cnMaestro URL [ 192.168.200.10], disabling Server Cert check
2021-08-24 15:30:29 8603 device-agent.c:1953:Allowing all certificates
2021-08-24 15:30:30 8603 https-client.c:733:SSL_ERROR_WANT_READ try again
2021-08-24 15:30:30 8603 https-client.c:724:SSL_connect successful
2021-08-24 15:30:30 8603 https-client.c:763:Server certificate is verified and it is valid
2021-08-24 15:30:30 8603 https-client.c:777:SSL write 165 bytes
2021-08-24 15:30:30 8603 https-client.c:804:Wait for headers from router,max_tries =0
2021-08-24 15:30:30 8603 https-client.c:808:Received 320 bytes
2021-08-24 15:30:30 8603 http-header.c:36:Found end of http headers
2021-08-24 15:30:30 8603 http-header.c:214:HTTP content-length is 158
2021-08-24 15:30:30 8603 https-client.c:635:Error response: [{"message":"Page Not Found","_links":{"self":{"href":"/admin/cns-onboarding/device?mac=b2021-08-24 15:30:30 8603 https-client.c:871:get_from_cnsrouter: Received 404 from cnRouter ret=0
2021-08-24 15:30:30 8603 https-client.c:890:get_from_cnsrouter: max_tries 1, ret 0 , error 1
2021-08-24 15:30:30 8603 discover-cns.c:53:Not able to find cnMaestro, Try Discovering again
2021-08-24 15:30:30 8603 discover-cns.c:147:Slow rediscover: idle_timeout 340
2021-08-24 15:30:30 8603 discover-cns.c:256:Discovery of cnMaestro Failed
2021-08-24 15:30:30 8603 device-agent.c:2529:Unable to discover cnMaestro URL (re-discover in 340 seconds)
2021-08-24 15:30:30 8603 device-agent.c:2421:Previous state 1 new state 0
2021-08-24 15:30:30 8603 device-agent.c:2440:da_enter_state:DA_STATE_IDLE
2021-08-24 15:30:30 8603 device-agent.c:2459:started discover timer, idle_timeout = 340
2021-08-24 15:30:30 8603 device-agent.c:2461:Attempting (re)connection in 5 minutes
2021-08-24 15:30:30 8603 wifi.c:1932:platform_set_cns_connection_state: New Connection_state Connecting(4)
2021-08-24 15:30:30 8603 wifi.c:1967:platform_set_cns_connection_state: idle_timeout=340
Any help is appreciated.
