Opening https sites in PMP 1000 set to PPPOE client does not work. only http.
Hello lineu,
We are not aware of any limitations on PPPoE that would prevent you from accessing HTTPS sites. On the other hand, there could be connectivity issues with PPPoE due to MTU mismatches. ePMP PPPoE implementation supports a maximum MTU of 1492 bytes.
Regards,
Luis
MTU pppoe server 1480
MTU CPE cambium 1480
clamping enable
all http work!!!!!!!!!
