Organizing 450 APs
Under System I created a Network for geographic region of our network.
Under that I created a Tower site.
Is there a way to make AP groups under the tower?  I have a cluster of 900, 3.6 and 5.x all at same site and would rather they are organized into seperate AP groups but under same tower.
Also, when I look at map there are no roads etc on it.
Are you wanting to organize them into frequency groups... like put all the 900MHz AP's into one, 5GHz, into another and so on?
From what I'm seeing you can't nest lower then System -> Network -> Tower -> AP's
I guess you could name your Network the tower site, and then each tower would be a band, and then assign the correct AP's.
