Hi All,
Is there away to lock the power level in the orthago 30/60 backharls to 25 dbm? ours is running at 19 dbm, I really could use the extra power
I believe the power levels are set at by the distributor per region. You’d need to get a key for a region that is aloud to use higher power out put.
From the manual, the different modulation modes have different maximum power outputs (region dependant).
BPSK – +25 dBm
QPSK – +23 dBm
16QAM – +21 dBm
64QAM – +19 dBm
So, if you want more power, drop the modulation mode (and throughput).
Aaron
