I am looking to perfom a "Reset Stats" for all of our SMs globally. Is there a json script I can run via a template in cnMaestro that can accomplish this??
I don't think it is possible today.
It can done through SNMP set command.
cambiumStatsForceUpdate OBJECT-TYPE SYNTAX Integer32 (0|1) MAX-ACCESS read-write STATUS current DESCRIPTION "Cambium Statistics Update/Reset Action Statistic is updated automatically in the background each 15sec SNMP-GET on This OID forces update of subsequent Statistics tree SNMP-SET on This OID Resets all of the subsequent Statistic Device Allocation: AP, SM" ::= { cambiumPerformanceMonitoring 1 }
I will doublecheck whether it can be somehow done in cnMaestro and revert to you shortly.
Thank you.
