Get pinpoint accuracy on planning multi-gigabit speeds over fixed wireless and save time and money while delivering “wow” speeds to subscribers. cnWave, our 60 GHz multi-gigabit fixed wireless broadband solution, has now been added to the cnHeat planning tool. Network designers can quickly and easily model cnWave deployments and obtain RF 3D accuracy at every square meter of the heat map. cnHeat uses high resolution LiDAR to accurately model the earth and the buildings and vegetation on the earth. This allows RF propagation models to generate accurate RF plans at every square meter. Field tests and feedback from network operators prove out the accuracy of our heatmaps as best in class.
This is a companion discussion topic for the original entry at https://www.cambiumnetworks.com/blog/plan-60-ghz-deployments-for-multi-gigabit-performance/
