The connection of that particular screen is not POE related.
The LAN side from the POE to the router is what is showing 10mbps.
Its either you need to so alignment of the ratio to get a better throughput or change the frequency to achieve the speed desired after getting rid of the 10mbps.
Go on the AP this SM is connected to.
Login
click on Tools
click on Automatic Channel selection
Toggle to enable
Click save at the top
Then click RUN ACS
wait for the output - leave that screen on - it will show you the frequencies
I tend to avoid channels lower that 5.4 zone - l like anything between 5.40 to 5.85 that has zero or one interference.
Write down your choices
Go back to configuration, disable automatic frequency selection
choose the choice that you concluded on
Save it and test.
How to test.
Log into the SM
Go to tools and choose Wireless Link test and run test
You will see the maximum throughput that that SM will get.
Great Frederick, I must say here a big thanks to you and everyone that has made some much effort to explain to me how to go about the issue I have with this device (Cambium networks) God bless you all.
Here is a screenshot I took from an SM with our AP it could see.
The coz2w is the one with the issue that customers connected complain that itās very slow even when they have a link of -65 and MCS is 11/12 for upload and download. de-wr-ap-06, de-wr-ap-12 coz2N, and coz2w are the APs on our tower.
Joseph, this is just your network in TDD mode.
There are other networks flying around that are not in TDD mode which the scan will not see.
There are certainly more interferences than this.
The fact that you have a low RSSI and good MCS does not necessary mean a good connection.
Also, it is not about spacing out the frequencies that makes it better.
5840 is not the best frequency towards your current customers connecting to that sector.
You need too scan for alternate frequencies and see if they fit better.
You need access to Coz2-W and you need to play around with frequencies after you scan & see the best available frequencies for the section that Coz2-W faces within that 90 degrees.
A link of -65 and MCS is 11/12 for upload and download is very good if on the best frequency.
You need to find the best frequency to get the best output.
Can you let me know what the solution was?
It is good to let us know so we can help someone else better next time.
So, please share with me the solution.
of another AP with SM attached⦠I just donāt know when my CTO would be able to have the time to look into these customer issues and resolve them. what do you advise @Fobasanjo@zica49
If you do not have access to the AP, then you can extend the height of the SM.
If the SM height goes higher, RSSI will drop from 75 to something lower and this will give you better service.
At this point, I will advice that you email your CTO to give you passwords for APās so the you can log into APās and do more troubleshooting. If you get the passwords, I can remotely help you.
You can email me at FFalade@i-browse.net if you need more help.
Which country are you?
Your connection is only 10Mbps. You need to check your cables or terminations
Your signal is way too low. You need to figure out what is blocking the LOS to your AP. May need to raise the radio up or relocate it to another spot that gets a better sight towards our AP
Do a spectrum analysis to see if there is something between your radio and the AP that is using the same frequency channel as you are broadcasting on.
