Hi All,
I have few PMP430 which are on version 11.2
I'm about to upgrade them to version 13.4.1, my goal is to do that with the less service disruption possible
One of the main reasons of the upgrade is that some of our SMs are mobile, and we will start deploying 450 AP, so the compatibility mode on the SM is required
I'm planning to follow the upgrade path below
11.2->12.1.2->12.2.1->13.1.4->13.4.1 using CANUT 4.9.18
My questions are :
1- What do you guys thing regarding this upgrade path, can it be optimized (keeping in mind that we want to achieve the seamless upgrade possible).
- Do you advise me to use the auto-upgrade feature or do you advise upgrading the SMs manually than upgrading the AP
Any suggestions\ recommendations are welcome
Many thanks in advance for your help
Kind regards
Mehdi
