Hi, a SM PMP 14.1.2 (Build 13) SM-AES has many disconnection from AP. 123 (CANOPY 14.1.2 (Build 13) AP-AES 5.4GHz MIMO OFDM).
Downlink Status
| Receive Power : | -70.5 dBm ( -74.0 dBm V / -73.0 dBm H ) |
| Signal Strength Ratio : | -2.0dB V - H |
| Signal to Noise Ratio : | 26 V / 25 H dB |
| Beacons : |
99 % |
| Receive Fragments Modulation : | Path V:QPSK:38% 16-QAM:38% 64-QAM:24% Path H:QPSK:33% 16-QAM:34% 64-QAM:33% |
Event log SM
System Event Log
04/23/2016 : 15:02:33 CET : :user=unknown; *System Log Cleared*; 04/23/2016 : 15:02:33 CET : :Remote clrsyslog. 04/27/2016 : 01:30:06 CET : :Time Set 04/27/2016 : 01:23:06 CET : :Time Set 04/27/2016 : 06:00:16 UTC : :Timezone set to UTC; 04/27/2016 : 08:31:41 CET : :Timezone set to CET; 05/28/2009 : 18:23:07 CET : :Time Set 04/28/2016 : 18:33:07 CET : :Time Set [....] 05/02/2016 : 12:59:10 CET : :Web user; user=none; Reboot from Webpage; |
There are 4 parameters that seem to vary with each fall(a fall approximately every 15 minutes):
Radio Statistics
| Transmit Control Count : | 21 |
| Receive Control Count : | 19 |
| In Sync Count : | 13 |
| Out of Sync Count : | 3 |
Telnet SM
Telnet+> gpsinfo
Unrecognized GPS Type
Unknown
GPS Model:
Rcvr Status:
Chnl 0 0 00 00 00
Chnl 1 0 00 00 00
Chnl 2 0 00 00 00
Chnl 3 0 00 00 00
Chnl 4 0 00 00 00
Chnl 5 0 00 00 00
Chnl 6 0 00 00 00
Chnl 7 0 00 00 00
00/00/0000 00:00:00 Visible-00 Tracked-00
Latitude: N00 00.0000
Longitude: E00 00.0000
Height: 0 meters
PPSMode 0 PulseStatus Off
NoMatch:0 NotValid:0 UpdEa:0 CharCnt:0 nEnRsp: 0
Event log AP 123
full of these lines
03/30/2010 : 06:48:55 CET : :Time Set 05/03/2016 : 06:48:58 CET : :Time Set 05/05/2016 : 08:03:01 CET : :Time Set 05/03/2016 : 06:50:32 CET : :Time Set 03/03/2010 : 07:16:02 CET : :Time Set 05/03/2016 : 07:16:06 CET : :Time Set 03/03/2010 : 07:37:55 CET : :Time Set 05/03/2016 : 07:37:56 CET : :Time Set 03/03/2010 : 08:26:33 CET : :Time Set 05/03/2016 : 08:26:34 CET : :Time Set 05/06/2016 : 12:25:03 CET : :Time Set 05/03/2016 : 09:32:54 CET : :Time Set 05/03/2006 : 11:07:19 CET : :Time Set 05/03/2016 : 11:07:22 CET : :Time Set |
AP 123
| Registered SM Count : |
21 (33 Data VCs)
| Sync Pulse Status : | Receiving Sync |
| Sync Pulse Source : | On-board GPS |
| Maximum Count of Registered SMs : | 24 |
| Sync Pulse Status - On-board GPS : | Receiving Sync |
| Sync Pulse Status - Timing Port/UGPS : | No Sync |
| Sync Pulse Status - Power Port : | No Sync |
| UGPS Power Status : | Power Off |
| Satellites Visible : | 13 |
| Satellites Tracked : | 10 |
| GPS Date : | 05/03/2016 |
| GPS Time : | 10:38:02 |
| Tracking Mode : | 3D Fix |
| Latitude : | 44° 34' 15.81" N |
| Longitude : | 10° 41' 8.26" E |
| Height : | 410.3 meters |
| Invalid Message Count : | 406282 (increase every second) |
| Site Map : | Map [AP123] |
Note: This is only an approximation on the physical location. |
| GPS Receiver Information : | Canopy iGPS (GPS) |
Telnet AP 123
Telnet+> gpsinfo
Result: http://textuploader.com/5yi83
There is another equal AP in the pylon, AP 122 and messages from GPS are different:
Event log AP 122
03/05/2010 : 14:02:08 CET : :Time Set 05/03/2016 : 07:10:30 CET : :Time Set 03/06/2010 : 10:04:00 CET : :Time Set 05/03/2016 : 09:10:41 CET : :Time Set |
23 (33 Data VCs)
| Maximum Count of Registered SMs : | 23 |
| Satellites Visible : | 14 |
| Satellites Tracked : | 11 |
| GPS Time : | 12:16:03 |
| Latitude : | 44° 34' 15.28" N |
| Longitude : | 10° 41' 8.53" E |
| Height : | 404.6 meters |
| Invalid Message Count : | 167892 |
| Site Map : | Map [AP122] |
| GPS Receiver Information : | Canopy iGPS (GPS) Function: 3 Software Version: AXN_1.30 Software Revision: 2501 Software Date: 004-20-2011 Model: FGPMMOPA6B*1E |
Customer 1 |
1 |
1 |
0 |
6 days, 15:21:39 |
Primary |
0.162 miles (860 feet) |
1750 |
17 |
LUID: [0a-00-3e-b2-1f-9f] antenna with problem |
42 |
22 |
1 |
00:03:23 |
Primary |
10.232 miles (54028 feet) |
109925 |
1099 |
There is a problem with our GPS? This problem is linked with the problem with our PMP450?
