ADI Communications failure, and ADI Catalina R1 Chip Not Supported Errors! Anyone else seeing this on the PMP 450 SMs? I have had 7 come in over the past couple weeks!
@bowie0570 wrote:ADI Communications failure, and ADI Catalina R1 Chip Not Supported Errors! Anyone else seeing this on the PMP 450 SMs? I have had 7 come in over the past couple weeks!
Please provide CNUT captures for these radios. They can be sent to:
I have one 450 SM with ADI Communications failure. New, in service for just a few hours before it failed.
Stuck in a reboot cycle. Won't say up long enough to do anything with it.
@mhughes wrote:I have one 450 SM with ADI Communications failure. New, in service for just a few hours before it failed.
What SW version?
Can you insert a Default Plug into the SM and see if the reboots stop?
If they do, this could be from an issue with one of the configuration parameters on the SM.
Tried with default plug. No difference. I did manage to get in and reset to factory defaults.
Tried to upgrade to 13.4b-11. Unit stops during the update process and fails.
System Reset Exception -- Watchdog Reset Cur ExtInt 0 Max ExtInt 0 Cur DecInt 0 Max DecInt 0 Cur Sync 0 Max Sync 0 Cur LED 1 Max LED 1 Cur WDOG 0 Max WDOG 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 0 Cur FPGA 0 Max FPGA 0 Cur FrmLoc 0 Max FrmLoc 0 Cur WatchDog 33 Max WatchDog 33 RTMLogStats 0 AAState 0
Software Version : CANOPY 13.2.1 SM-DES
Board Type : P11
Device Setting : 5.4/5.7GHz MIMO OFDM - Subscriber Module - 0a-00-3e-b2-59-f1
Default plug overrides configured parameters
FPGA Version : 081514
FPGA Features : DES, Sched;
01/01/2011 : 00:04:05 UTC : :ADI communication failure
01/01/2011 : 00:04:05 UTC : :InitADI936x() : Catalina register failures, ADI forced reset has been invoked!
@mhughes wrote:Tried with default plug. No difference. I did manage to get in and reset to factory defaults.
Board Type : P11
What was the CNUT error? Can you put this SM on a public IP and I can try to upgrade it to 13.4 for you? If this is happening on every boot, please contact Cambium Support.
I've tried public IP's. Same results. I'll contact support.
07/02/15 16:41:14 INFO Refresh Entire Network process start ..
07/02/15 16:41:14 INFO Refreshing NE at:169.254.1.1
07/02/15 16:41:14 INFO NE at:169.254.1.1 refreshed.
07/02/15 16:41:14 INFO Refresh Entire Network process has completed.
07/02/15 16:41:19 INFO Updating Entire Network process start ..
07/02/15 16:41:19 INFO CANOPY134BUILDOFFICIAL_MIMO_PMP450_DESAES_S.pkg3 loaded.
07/02/15 16:41:19 INFO Starting Update Process ..
07/02/15 16:41:19 INFO Queue NE:169.254.1.1 for updating
07/02/15 16:41:20 INFO Host: 169.254.1.1;ESN: 0A003EB259F1;Message: Checking Network Element Status (SITE= No Site Name)
07/02/15 16:41:20 INFO Host: 169.254.1.1;ESN: 0A003EB259F1;Message: Current = CANOPY 13.2.1 SM-DES, CANOPYBOOT 1.0, 081514 (SITE= No Site Name)
07/02/15 16:41:20 INFO Host: 169.254.1.1;ESN: 0A003EB259F1;Message: Using Package C:\Users\Michael\Desktop\PMP450\CANOPY134BUILDOFFICIAL_MIMO_PMP450_DESAES_S.pkg3 (SITE= No Site Name)
07/02/15 16:41:20 INFO Host: 169.254.1.1;ESN: 0A003EB259F1;Message: No master/slave register link detected. (SITE= No Site Name)
07/02/15 16:41:20 INFO Host: 169.254.1.1;ESN: 0A003EB259F1;Message: Transferring Files 5x_cat120.img to host:169.254.1.1 by http (SITE= No Site Name)
07/02/15 16:41:34 INFO Host: 169.254.1.1;ESN: 0A003EB259F1;Message: Programming ... (SITE= No Site Name)
07/02/15 16:42:34 WARN Host: 169.254.1.1;ESN: 0A003EB259F1;Message: Update not started. (SITE= No Site Name)
07/02/15 16:42:34 INFO Node: 169.254.1.1 Update Completed.
07/02/15 16:42:34 INFO Refreshing NE at:169.254.1.1
07/02/15 16:42:34 INFO Autoupdate Skipped: As AP ne:169.254.1.1 failed to upgrade.
07/02/15 16:42:43 INFO Updating Entire Network process has completed.
SW Version 13.3
Still gives the error with a defualt plug in
@bowie0570 wrote:SW Version 13.3
You will have to contact support.
bowie0570,
Please contact support and provide both the ESN and MSN of the radios. Identify which ones are seeing the ADI Communications Failure and which ones are seeing the ADI Catalina R1 Chip Not Supported errors.
These radios will need to be replaced via our standard RMA process.
http://www.cambiumnetworks.com/support/rma-request/rma-form/
