Beginning with R14.1.1, we've added Frame Alignment Legacy Mode to the firmware, as a tool to help align timing when different software versions. This information comes from the R14.1.1 Release Notes:
In order to facilitate field hardware upgrades/replacements, "Frame Alignment Legacy Mode" has been added to newer software releases to allow for co-location with radios running older Canopy versions which cannot be upgraded at the same time, or to allow for slow rollout of upgrades on a per-sector basis, while maintaining compatibility with nearby sectors.
The best solution for resolving frame alignment issues for co-location is to maintain deployment of the latest software builds.
The web management interface contains a table (located at Configuration > Radio > Advanced) to reference which setting is appropriate for your network based on software versions and synchronization sources:
Figure 3 Frame Alignment Legacy Mode (non-900 MHz)
Figure 4 Frame Alignment Legacy Mode (900 MHz)
Please refer to the AP’s web management interface at Configuration > Radio > Advanced to determine the setting for the Frame Alignment Legacy Mode based on your network deployment. Note that this table differs between 900 MHz and 5 GHz hardware.
When utilizing Frame Alignment Legacy Mode, legacy radios must remain on a fixed synchronization source, or the Frame Alignment Legacy Mode parameter must be adjusted to accommodate the changes of the legacy radio synchronization source. New devices with Frame Alignment Legacy Mode set to ON (Mode 1 or Mode 2) will remain in synchronization with the legacy radio even if its own synchronization source is changed.
Table 12 Frame Alignment Legacy Mode attribute
Attribute |
Meaning |
Frame Alignment Legacy Mode |
In order to align the frame start of co-located systems, the Frame Alignment Legacy Mode has to be selected from following options:
