What is the minimum physical distance for two PMP 450 AP cluster with in the same tower using the same frequencies?
It depends on what you're trying to do, and what antennas you're using. If you're trying to use GPS sync and back to back frequency reuse, you'll need to make sure you're either using a Cambium OEM antennas OR an antennas with 30dB or greater front to back ratio. This will allow you to have the antennas mounted just a few feet away from each other without issues.
