im new to cambium and i have this pmp450 and SM100 , i wonder about what settings should i use , the distance from AP PMP450 to SM 100 is 2 miles , i set the region , frequency , channel width on the AP and on SM i set the ap selection method to power level ....
what else should i set or take care of it ... ? please advice
coming back to your problem, make sure region code, frequency, channel bandwidth, cyclic prefix are all matching in AP and SM. Instalation Color code should be enabled.
On AP , what are sync setting under Configuration ->General, if you are using AutoSync then AP must have a GPS Sync pulse.
Generate sync is fine, What does Spectrum Analyser show ?
Can you upgrade your setup to 13.4 , if yes please send me your configuration file of AP and SM, they are placed under Configuration -> Unit Setting , Download them and attach here.
