I have an issue with updating some 450 SMs. I get a couple of errors.
From the unit
Incompatible Software Version With cnMaestro (cloud.cambiumnetworks.com - Default Cloud URL)
CNUT complains
Connection reset by peer: socket write error
Thoughts?
From the unit
CNUT complains
Thoughts?
Can you provide a bit more information?
What model radio are you trying to update?
What version of software is on it currently? (Homepage screenshot would provide a lot of info)
What version of CNUT are you using?
