Will we ever see the PMP450d in 3.6 ghz? I see an 450i version 3.6 with integrated antenna but its too expensive for most applications.
We researched doing just that (a 450d in 3.65 GHz), but to get reasonable gain, the size of both the patch and reflector changed significantly, and would have required significant effort. In the end, releasing the High Gain Directional 3.65 GHz SM (which is a 450 SM, not 450i) was a better option for most customers.
If price is the obstacle, discuss pricing with your local reseller and/or your Cambium sales manager.
Also, keep in mind, we will be releasing a 450i 3.65 GHz SM in Q4 as well.
Do you have a link to the specs or PDF on this?
http://www.cambiumnetworks.com/products/access/pmp-450/
I do not see it here.
It is under spec sheets on the right... the name may be a bit obtuse:
http://www.cambiumnetworks.com/resources/pmp-450-3-ghz-ruggedized-sm/
