PMP 450i and Power on reset issue
Good morning.
We have some serious issues with the new PMP 450i AP's.
Randomly they reboot with the "POWER ON RESET" message like there was a lack of current but we are sure that there're not power outage on our tower and are afflicted near 90% of our PMP 450i.
Exemple Log:
System Reset Exception -- Power-On Reset
Software Version : CANOPY 14.1.1 AP-AES
Board Type : P13
Device Setting : 5.4GHz MIMO OFDM - Access Point - 0a-00-3e-bb-XX-XX - 5480.0 MHz - 20.0 MHz - 1/16 - CC 13 - 2.5 ms
FPGA Version : 110915
FPGA Features : AES, Sched, US/ETSI;
05/02/2016 : 09:15:43 UTC : Acquired sync pulse from Timing Port/UGPS.
05/02/2016 : 09:15:44 UTC : :GPS Date/Time Set;
This issue occour with various type con AC power like CCM4, UGPS, Generating Sync etc... and various firmware version (14.1.1 stable, beta 10 and beta 14)
Seems like a Watchdog Reset with a different name...
We have opened various support cases and seems will be fixed on the nexts releaes (they told me 14.3 but I hope much earlier...)
Someone has the same problem?
Thanks!
If your APs are connected to get power CMM4, make sure CMM4s not having public IP address because their are some malformed telnet packet that could have cause CMM to get crashed and hence all power port reset and thats the reason you see power on reset.
Cross check CMM4 of any crash. ?
Chitrang
Our CMM4's have all private IP.
The problem is not CMM4 because the "power on reset" occours on different port, not all together and with UGPS and various firmware version (14.1.1 stable, beta 10 and beta 14).
Thank you Chitrang!
UPDATE:
Cambium support told me that this issue will be fixed in the 14.2 release.
Same problem, we await the fix:
Device Type :
Software Version :
CANOPY 14.2 (Build 15) AP-AES
*****System Startup******
Software Version : CANOPY 14.2 (Build 15) AP-AES
Board Type : P13
No valid accounts configured. Using default user account - 5505.0 MHz - 20.0 MHz - 1/16 - CC 13 - 5.0 ms - Other Regulatory/Other
FPGA Version : 040716
05/16/2016 : 14:14:07 UTC : :Time Set
05/16/2016 : 14:14:25 UTC : :Board Temperature : 23 C / 73 F
05/16/2016 : 14:14:27 UTC : :GPS Date/Time Set;
05/16/2016 : 14:14:35 UTC : Acquired sync pulse from Timing Port/UGPS.
We are investigating this internally and have reproduced it.  This has nothing to do with the 450 "watchdog reset" that was fixed in 14.1.2.  That issue had many outcomes from a single root cause, of which "watchdog reset" was one such outcome.
Regarding this issue which only affects (and can only affect) 450i, we are doing everything we can to get a fix for this into 14.1.2 before its final release. The HW and SW architectures of 450i vs 450 are very different which is why these two issues have nothing in common with each other.   14.1.2 was planned to go to release today but is being held up now while we investigate this.  I'm hopeful that we'll still be able to push a release sometime next week with  fix for this as well as improved reset reporting on 450i.
hi
am peter from nigeria, my cambium pmp m2000 keep reseting every week,the customer keep complaning.
i use to visit the customers for reconfiguration.
please how can i solve the reseting issues?
Peter-
    I am not clear which device you are having resets on.  You mention PMP m2000.  Is this the ePMP 2000 or something else?  If it is ePMP you will want to use the ePMP forum http://community.cambiumnetworks.com/t5/ePMP-3000-2000-and-1000/bd-p/forums_epmp_1000  for better results.
If this is a PMP 450 radio?   Are there any log messages?   No matter what model of radio you can collect any information you have, open a ticket and post the ticket number we can take a look at the issue.
Submit a request at:
https://support.cambiumnetworks.com/
Or other support contacts are listed at:
https://www.cambiumnetworks.com/support/contact-support/
