Hello,
do you think 450i Sm or 450b high gain sm are compatible with PMP 450 Access point and can work !
if yes, is there a compatible software verion !
Thank you
Hello,
Thank you
Yes, this is a compatible combination. It's always recommended to be on the latest software version. If both devices are running the same version, however, it should be fine with any version.
See this page for the latest software.
