Is anyone having trouble mounting the 450i AP to the cambium 60 degree sector antenna (85009325001). seems like the bolts included are too small and when the correct size bolts are used that the mounting plate no longer aligns to the holes on the AP.
Yes, in future shipments of the connectorized 450i, we will include the correct mounting bolts that will allow this to work. Apologies for this.
We will be issuing a FSB on this topic so people are aware.
I can send you bolts. Please send me an email with your shipping address, and we'll get them to you right away.
matt@cambiumnetworks.com
Matt
Thanks Matt, You may also want to look at the mounting plate as the alignment seems a bit off.
@Chris Chacon wrote:Thanks Matt, You may also want to look at the mounting plate as the alignment seems a bit off.
Chris,
The bolts that Matt will send you have a small neck which will allow your mounting plate to be attached to the radio.
Best,
Cambium Jonathan
Got it , just had to hold the plate up while I started them, again thanks for the help guys
