I've got 3 PMP 450m APs. The first two were running 15.0.1, and they seem quite stable. The third was installed with 15.0.2, and is now running 15.0.2.1 - this one has been randomly dropping sessions.
One of the recurring thing I'm seeing in the SM Session Logs of the SM which do drop a lot are things like this:
This particular SM reports its Air Delay as "38050 ns, approximately 3.541 miles (18701 feet)" (AP Range is set to 15 miles)
I notice under Statistics-> Scheduler that the "Scheduler Error" field increments when these issues happen. Signal quality is not great, but reasonable, and Spectrum Analysis didn't show any noise. Any ideas?
Tools → Link Status 5.4/5.7GHz MIMO OFDM - Subscriber Module 0a-00-3e-bx-xx-xx
Scheduler errors and re-registrations aren't my particular area of expertise but I know a couple of engineers here that are looking at that sort of thing, there are improvements for re-registrations coming in the 15.0.3 release (although I'm not sure you are describing exactly the same fault). If you could collect the engineering.cgi and send that on I could add it to the information they are looking through.
I updated the firmware on this AP to 15.0.3 early Thursday morning, and I would have to say, at this time, this firmware loadout does not appear to result in any improvement on this issue.
There might be totally different causes between this symptom occurring on a 450m vs. a 450 (or 450i).
We have addressed this issue further on R15.1, which will be released today (hopefully).
Regarding it happening on the 450 as you mention SBC... I think we need more information to try to help. Maybe better to start a new thread (as this one pertains, and is likely specific to, the 450m).
We've been having this issue for over a year on the PMP450 3.65. Nothing has ever been resolved. Good luck and if you find something, please let me know.
As mentioned to SBC above, we've resolved this issue which was specific to 450m. Dropping sessions can be caused by numerous things, and typically the culprit is interference.
I would suggest starting a separate thread, and we can dig into it there.
I was the original poster, and I haven't seen that problem recur since I went to 15.1 firmware. I would regard the issue in my post as having been solved.
we currently have a pmp 450m that keeps dropping customers at random, and bringing them back. in addition, the few customers that remain connected either have slow speeds or no internet at all. we even tried to connect new SMs to the unit, but they connect perfectly… but no traffic passes through them. any ideas?
