I just opened our new PMP 54430 (5.4 Ghz). While going thru the configuration I do not have an option to set the channel bandwidth. It seems like its hard set to 10 Mhz. Software version is 10.5. Anyone with the same problem?
On which site do u want do change channel bw? Sm or AP?
On AP u have to change channel bw with Cnut.
On SM u have to change it under the Configuration–>Radio tab
More Info needed?
contact me here
greets Malte
Is there a con to changing it to 20mhz?
Why would they make it so you have to use CNUT to do it and not just have it as an option the GUI?
tecnically: the cnut put a entire different firmware.
