So I am anxiously waiting for cnRanger, but in the mean time we are deploying Telrad's LTE product. We have been happy so far with the solution. I have a question though. We are going to attempt to run both the 320AP and a Telrad Compact into the same 4x antenna. 2 ports for each. I am trying to sync up the blocks in a frame and to do this I need to know a bit more about the how the Map symbols (5 or 7) and the extended range feature manipulate the frames.
As of now if the 320 is set to 75/25 - 10mhz channel. I believe I have them in-sync except for about a 0.5% overlap. or ruffly one block.
The base assumption on the 320 is:
10mhz channel size
75% download = 35 down blocks
25% upload = 12 up blocks
5 map symbols = 0 (?) blocks (upload or download?)
Extended range yes = 0 (?) blocks (upload or download?)
Total blocks in one frame = 47
Does this look right?
