What is difference between low priority and high priority VC and why would they run at different modulations on a PTP450?
I assume that based on tagging you can give some packets a higher priority and if the link is busy they will have precedence but I do not see why that would affect modulation rate?
Thanks.
hci,
The difference between the two VCs is only the scheduling. The High Priority VC will always be sent first.
They have different modulation rates only when there is no traffic going over the other VC. If traffic is going over both VCs, their modulation rates will match. For example if there is no High Priority traffic, you will see the Low Priority VC modulation rate start at 1X and rate adapt up to lets say 6X, but the HP VC will stay at 1X. Then once traffic is sent it will rate adapt up as well.
We are considering changing this in a future release where all the VCs could share the same rate adapt on the same radio.
