Just wondering which version of excell is compatible with your capacity planner ? I'm getting the following error when I try and change fields like Frequency band , Region , AP Model etc etc.
Comile error in hidden module: Sheet2.
This error commonly occurs when code is incompatible with the version, platform, or architecture of this application.
I attempted the latest version of the Capacity Planner on the two versions of Excel that I have available to me. (2007 and 2016)
It worked fine on Excel 2016, but I received the same error as you for Excel 2007.
It sounds like it might require Excel 2016.
It should be possible to go into the archives and use an older version of the Capacity Planner with Excel 2013...although I am not sure how far back you will have to go.
