Good morning all, this is my first post on this forum. Forgive and correct me if I'm wrong in something.
My company has recently installed a small system composed by 1 PMP450 AP (licensed for a maximum of 10 SM), 2 PMP 450 SM capped@20Mbps and 3 PMP 450 SM capped@10Mbps. It'all fine except for only one SM (capped@10Mbps) that regulary disconnect every 27 minutes. The connection is regulary re-established after about 45 seconds.
Some of you has ideas I can investigate on?
Any help is appreciated!
Regards.
f.
Attached some basic info
Device Type : 5.4/5.7GHz MIMO OFDM - Subscriber Module - 0a-00-3e-xx-xx-xx
Board Type : P11 C120
Software Version : CANOPY 14.1.1 SM-AES
Board MSN : 6069RSxxxx
FPGA Version : 110815
Uptime : 4d, 15:38:38
System Time : 10:21:23 03/23/2016 CET
Ethernet Interface : 100Base-TX Full Duplex
Region Code : Other
DFS : Idle
Antenna Type : Integrated
Frame Period : 2.5 ms
Temperature : 41 °C / 106 °F
Some "SM Authorization Logs"
03/23/2016 : 08:46:16 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 08:46:16 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
03/23/2016 : 08:47:07 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
03/23/2016 : 08:47:36 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
03/23/2016 : 08:47:36 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
03/23/2016 : 08:47:37 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 08:47:38 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
03/23/2016 : 09:12:46 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
03/23/2016 : 09:14:07 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
03/23/2016 : 09:39:45 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
03/23/2016 : 09:40:19 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:40:20 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:40:20 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 09:40:20 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
03/23/2016 : 10:06:35 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
03/23/2016 : 10:07:00 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
03/23/2016 : 10:07:00 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
03/23/2016 : 10:07:01 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 10:07:01 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
03/23/2016 : 10:07:56 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
03/23/2016 : 10:08:26 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
03/23/2016 : 10:08:26 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
03/23/2016 : 10:08:25 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
03/23/2016 : 10:08:25 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
And finally some "SM Authentication Logs"
03/23/2016 : 08:20:07 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:20:07 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 08:20:54 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 08:21:25 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:21:25 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:21:25 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 08:45:46 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 08:46:16 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:46:16 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:46:16 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 08:47:07 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 08:47:36 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:47:36 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 08:47:36 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 09:12:46 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 09:13:13 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 09:14:07 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 09:14:38 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 09:39:45 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 09:40:19 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 09:40:19 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 09:40:19 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 10:06:35 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 10:07:00 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 10:07:00 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 10:07:00 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
03/23/2016 : 10:07:56 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
03/23/2016 : 10:08:26 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 10:08:26 CET : Event: AUTHEN_CHAL, NewState: AUTHENTICATING, Flag 0
03/23/2016 : 10:08:26 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
