Network:
PMP100 900Mhz network. Many sites with four and six sector arrays.
Firmware: 11.2
Sync Source: CMM3 (all sites)
Scenario:
Attempted to co-locate PMP 450i 900Mhz
PMP450i Firware: 14.2
Timing coordinated using the Cambium colocation tool
Frame Alignment Mode: On (Mode 2)
Sync Source: uGPS
Issue:
PMP100 APs within signal range of the PMP450i receive interference.
Test Scenario:
PMP100 Sector facing a PMP450i sector 9 miles apart.
Running Link Capacity Test for 10 seconds on select clients. Ten tests each
Benchmark: Run Test with opposing sector off and idle
PMP100 Results: 99% uplink efficiency
PMP450i Results: 90% uplink efficiency
Test 1: Run Tests Simultaneously
PMP100 Results: 18% uplink efficiency
Test Scenario #2
Running Link Capacity Test for 10 seconds.
Replace uGPS with power port timing. (Packet Flux Sync Injector timed via a CMM3)
Other Observations. Reg and Re-Reg counters increment on the PMP450i when there is regular activity on the PMP100, indicating that the PMP100 is interfering with the PMP450i when using power port timing.
Speculative Observation:
There is a difference between uGPS/Aux port timing and Power port timing.
Cambium 450i with uGPS is not compatible with PMP100 with power port timing via a CMM3.
Cambium 450i with power port timing via a CMM3 source is close to aligned, but not perfect.
Solution: None Known.
Notes: The PMP450i needed the distance changed to get an "OK" in the colocation tool, so I cannot dismiss the possibility that a configuration tweak could help and that the co-location tool is flawed.
