Hi…I am utilizing WS-12-250-AC running firmware adaptation 1.5.4, what is the right PoE setting for Cambium ePMP 3000 AP and Cambium ePMP 1000 2.4GHz Connectorized Radio GPS Adjust?
48v .75A is correct for both.
The ePMP 1000 2.4Ghz GPS radio can also run on 24v .75A.
Actually, let me clarify above - 48v is correct for the full 3000 AP. If you are running the 3000 lite, you must use 24v.
