Good morning and thanks for the reply
The following POE equipment can work with EPMP Force 200 5Ghz (C050900C161A). and EPMP Force 300 equipment?
UTP7204GE-HIPOE
SWITCH ETHERNET "INDUSTRIAL" | 4 PoE Gigabit 10/100/1000Base-Tx | Estándar IEEE 802.3af/at (PSE), support Poe+/PoE++ | 2 port SFP (Fibra óptica) y 2 port Gigabit uplink | Capacity : 17.5Gbps | Throughput: 10.4 Mpps |Operation : Plug and Play | Power Output PoE: 44 a 57Vdc, 60 Watts max. for port | Power Total PoE 60 Watts| Protection 6KV | Alimentación: DC 48V a 57V |Redundant power design, support power hot backup, standard DC port and green terminal port, Support power adapter with different connectors and power| UTEPO
