PoE Voltage for Client Mini
I have a deployment for a system and I am limited on space in my outdoor weatherproof box, I see hat the power input is 30Vdc on the Client Mini, my question is can I run this device off of a Hardened PoE++ switch that will located in my enclosure for my cameras or do I have to use the supplied power supply?
thanks
Joe
Client Mini needs passive PoE and is not 802.3af/at compliant. You can use Client MAXrp for this.
