Hello need your help..am using f550e but for my radio2 my uplink is so so better but for my radio one am getting worst uplink of 0mbps wondering what could be the issue
Hi. Your Radio1 link is modulating at a SS Modulation (Single Stream) on the upload, my guess would be that…
- There is noise on that frequency near the AP/Master side (so try changing channels, or try 40 or 20 Mhz channels to see if that rules out or rules in interference)
- Or the AP Side has a dead chain (deaf) on Radio1
or if it’s a connectorized version, maybe has a bad/wet/lose/broken Pigtail on the AP side. - Or on the SM Side had a dead chain (mute)
or if it’s a connectorized version, maybe the Slave side has a bad/wet/lose/broken pigtail.
Since it looks like the problem is just on one of the chains, I suspect a hardware problem with a radio, or a hardware problem with a pigtail or connector like #2 or #3 above.
However, the simplest thing first would be to rule out interference. So - I’d first try adjusting frequencies & widths first, just to see if other frequencies also show SS Modulation rates, or if that improves things to to DS modulations.
Also - you might try posting this in the ePMP group… I realize the 550’s are designated PTP-550, but they are ePMP’s in all meaningful ways, so maybe some ePMP Guru user there will have helpful suggestions. ![]()
Since Radio2 is fine, I’d focus on Radio1’s RF chain rather than the whole link. Check the AP and SM per-chain RSSI/SNR for Radio1: a strong chain imbalance or one chain with no signal points more to a radio, connector or pigtail issue, while both chains being noisy points more to interference. Also confirm both ends use the same channel width, check that Radio1’s Tx power isn’t pinned at maximum, and test a different channel/width. If per-chain values look healthy, consider whether the 0 Mbps uplink is a link-test or queue artifact.
