Is there a method to power cycle POE ports on a schedule with the TX1012-P-DC?
Hello Jules, ability to time PoE on/off is currently targeted in the 1st half of '2023.
how about a LVD? Can the POE ports be shut off if the system Voltage drops?
Jules,
You can give each port a PoE priority, and in case of low power input, the lowest priority ports will be disconnected, and the high priority ports maintained as long as possible, so yes, it has a form of LVD.
Perfect! Thank you very much for the update
