Anyone ever deploy power over ethernet cameras utilizing the POE from the CMM Micro to provide power? If so could you let me know what model cameras you used? Thanks!
i would not mess with CMM micro for a camera power supply.
I’m not even sure if Morotola’s implementation of POE to attached Canopy devices is the actual POE standard.
POE cameras are usually 12VDC (probably some exceptions)…Canopy/CMMmicro are 24VDC (typed 24VAC at first…oops). I would not try to use the CMMmicro to power ANYTHING other than Canopy equip, recipe for disaster in my opinion (and a pretty expensive POE injector
