Hi all,
I need a power supply for PTP 250, can a use the power supply for PTP 650 / PTP 670 (N000065L001C)? The pinout its the same?
Thanks.
Hi all,
Thanks.
Lucas,
A blast from the past with the PTP250. This is from the userguide below. At the time of printing the 650/670 did not exist. So you can use a PIDU to power the radio.
Select a suitable power supply unit for the PTP 250. The only supported units are the
PoE power supply (included in PTP 250 kits) or the PTP 300/500/600 Series PIDU. The
PoE power supply is suitable for the majority of installations.
