The system is composed of an ePMP2000 AP with sector antenna and smart antenna, the SM are FORCE-180, Force-200 and Force110 in NAT mode. Everything operates with firmware 4.4. The problem arises when installing a FORCE-130 in SM mode, which is not possible to access via Wlan and can only be accessed on its ethernet interface, nor is it possible to ping via WLan. It is possible to monitor it via cnMaestro because it has an internet connection and also allows ARP ping.
Any solution?
I have forwarded this to the support team.
