Problem in discovering element using PrizmEMS (closed)
Dear all,
I’ve already installed PrizmEMS Server, License Manager Server, and CNUT Server on my Linux RedHat Enterprise 4 box. The Canopy PrizmEMS Management Server web say that Server is Up. The Management Console (Java Web Start) is running too. There’s no such problem with the database mysql connection.
In my subnet, there’re a pc router as an internet gateway ; a Canopy AP ; the PrizmEMS server ; all connected by a small hub 10M. Approximately 200 meters nearLOS from the AP, I put a SM.
The first problem is I can ping the AP from the pc router (no need to argue, they’re in a same subnet). But I can not ping the SM (even in a same subnet), meanwhile I can access it by LUID from the AP; the SM is REGISTERED too. Is it anything wrong with my network?
The second and main problem is : The PrizmEMS still can not discover any element that connect to it. In this case is the AP. I don’t know what the matter is, but please take a look in to my PrizmEMS logs :
06/29/06 10:00:00 INFO SYSTEM Operation[Performance Logging Operation] start run …
06/29/06 10:00:00 INFO SYSTEM Polling performance data …
06/29/06 10:00:00 INFO SYSTEM Operation[Performance Logging Operation] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[Element - Poll Failed] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[Access Point - Unregistered Unit] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[Backhaul - Unpaired Slave] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[Element - Recently Rebooted] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[Backhaul - Unpaired Master] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[Element - Ethernet Down] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[RF - dBm Threshold Monitor] start run …
06/29/06 10:01:00 INFO SYSTEM Operation[Element - Poll Failed] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[RF - dBm Threshold Monitor] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[Backhaul - Unpaired Master] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[Element - Recently Rebooted] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[Access Point - Unregistered Unit] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[Backhaul - Unpaired Slave] status:completed_ok
06/29/06 10:01:00 INFO SYSTEM Operation[Element - Ethernet Down] status:completed_ok
06/29/06 10:02:30 INFO SYSTEM Operation[Bridge Operation] start run …
06/29/06 10:02:30 INFO SYSTEM Operation[ARP Operation] start run …
06/29/06 10:02:30 INFO SYSTEM Operation[Bridge Operation] status:completed_ok
06/29/06 10:02:35 WARN SYSTEM ARP OP failed:SNMPIOException:, error code: 9, varbind index: 0
request varbinds: Varbind: iso.org.dod.internet.mgmt.mib-2.ip.ipNetToMediaTable.ipNetToMediaEntry.ipNetToMediaNetAddress, null, 0, 9
Varbind: iso.org.dod.internet.mgmt.mib-2.ip.ipNetToMediaTable.ipNetToMediaEntry.ipNetToMediaPhysAddress, null, 0, 1
response varbinds: null
06/29/06 10:02:35 INFO SYSTEM Operation[ARP Operation] status:completed_failure
06/29/06 10:03:00 INFO SYSTEM Operation[System Maintenance Operation] start run …
06/29/06 10:03:00 INFO SYSTEM Operation[System Maintenance Operation] status:completed_ok
06/29/06 10:03:15 INFO SYSTEM Log Level Changed to : DEBUG
06/29/06 10:03:15 INFO SYSTEM Get Remote Service: Canopy.Prizm.BAMManager Requested from: 127.0.0.1
06/29/06 10:03:35 DEBUG SYSTEM Aging connection, try reconnect.
06/29/06 10:03:52 INFO SYSTEM Get Remote Service: Canopy.Prizm.NetworkDirectory Requested from: 127.0.0.1
06/29/06 10:04:05 DEBUG SYSTEM Aging connection, try reconnect.
06/29/06 10:04:16 DEBUG SYSTEM Aging connection, try reconnect.
06/29/06 10:04:44 DEBUG SYSTEM Aging connection, try reconnect.
06/29/06 10:05:00 INFO SYSTEM Operation[Performance Logging Operation] start run …
06/29/06 10:05:00 INFO SYSTEM Polling performance data …
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.PLVBR
06/29/06 10:05:00 DEBUG SYSTEM Aging connection, try reconnect.
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.PLVBR
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.HSBHS150
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.HSBHS150
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Generic.SNMP.Ports.26
06/29/06 10:05:00 DEBUG SYSTEM No element found for Generic.SNMP.Ports.26
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.AP
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.AP
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.BHS
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.BHS
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.Prizm
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.Prizm
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Generic.SNMP.Default
06/29/06 10:05:00 DEBUG SYSTEM No element found for Generic.SNMP.Default
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Generic.SNMP.Ports.8
06/29/06 10:05:00 DEBUG SYSTEM No element found for Generic.SNMP.Ports.8
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Generic.SNMP.Ports.16
06/29/06 10:05:00 DEBUG SYSTEM No element found for Generic.SNMP.Ports.16
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.BHM
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.BHM
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.CMM
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.CMM
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.SM
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.SM
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.PLVMD
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.PLVMD
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.HSBHM
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.HSBHM
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Generic.SNMP.Ports.24
06/29/06 10:05:00 DEBUG SYSTEM No element found for Generic.SNMP.Ports.24
06/29/06 10:05:00 DEBUG SYSTEM Polling elements of Canopy.HSBHM150
06/29/06 10:05:00 DEBUG SYSTEM No element found for Canopy.HSBHM150
06/29/06 10:05:00 INFO SYSTEM Operation[Performance Logging Operation] status:completed_ok
Well guys, please hit me with your comments!
Thanks.
Guys,
I’ve made some changes in my network configuration, ensuring that each element network has chosen the right IP for router and prizems server and the snmp-work-around parameters. After doing re-define on my network using prizmems management console, I tried the Auto Discovery feature of CNUT, and voila…, it began scanning my network and discovered all element network. And after that, my prizmems management console could find the element network in my subnet. It give me then, quite a lot of time to playing around with…
Case closed.
bekicotrasta wrote:
The first problem is I can ping the AP from the pc router (no need to argue, they're in a same subnet). But I can not ping the SM (even in a same subnet), meanwhile I can access it by LUID from the AP; the SM is REGISTERED too. Is it anything wrong with my network? .
Seems you choose "local" in IP Configuration page at SM
regards,
mrdlnf
regards,
mrdlnf
You're absolutely right! Thanks for reminding me. I'll keep it in my mind.
