I have a cluster with a combination of 4 AP advantage with software 7.2.9 and 2 AP no-advantage. In the first week muy cluster work good but a month ago, since i put the advantage, the sm that register in the adavantage start to experience some problem and the latency increase from 8-15ms to 200ms aprox.
I make a spectrum analyzer and it seems that there is not interference in the air. I dont know if the problem is the incompatibility with AP advantage and AP no-advantage in the same cluster.
All the AP sync with a CMM micro 2.0.8.
I would glad if you can give me some advices.
My email is rrincon@metroip.com
Yo uwill need to use the framing calculator in the Advantage AP to change the timing in order to colocate an Advantage AP and a non-Advantage AP. Read the manual and release notes for instructions.
Aaron
