not sure if this iwill be a problem but here are the details
RSSI:2076
-50dBm
jitter goes from 2 to about 9 every now and then. there are a few trees in the way but he is about .5 miles from the AP so i figure it wouldn’t matter much.[/u]
Are you in 2x mode or 1x mode?
1x mode, yes for sure that’s horrible.
2X
9 is acceptable in 2x mode.
Is that -50 at the AP?
WAY WAY too hot. As per our PM balancing is definitely in order.
Jerry Richardson wrote: Is that -50 at the AP?
yep. that my new project starting next week :D
We have noticed on some our 900 SM’s in certain locations drop peridoically if left in 2x mode whether the power level is -50 or -70. I would recommend turing off 2x mode for the time being to see if that solves the problem.
Hi Jerry,
I wonder if the noise floor level is at -45, shoud I still do the power Balancing?
Yes, we only have 2.4 choice here. Maybe 10+ wisp is using the same freq in every state.
Canopy is competing with XR2 from Mikrotik... :twisted:
Are you serious? -45 is the upper threshold of the AP.
Be sure you are looking at the noise floor with all of your AP’s turned off.
If -45 is for real personally I wouldn’t bother even trying to provide service much less worrying about balancing.
YES, that was seriously happened here.
XR2 is shooting at 600mW, and our canopy only 350mW.
We build 6 POP’s (every 3 kms) to cover our ass
All SM’s always +R or +WARM32
What do you think?
I think you’re in RF hell…
hope your ROI model works out.
Jerry Richardson wrote: I think you're in RF hell......
I dont think the ROI model is working. But someone must do it isnt it?
1 main POP with 5 small POP (3-4 AP's + BH) is covering our a*s
the concept of freq re-use is not working anymore where 10+ wisp is using the same band.
Should I build 5.7AP cluster?
What will happened if the authority know that we are using illegal freq?
:evil:
it is really really...undeveloped country....everyone is calling us as "developing country" but the fact is.....really "undeveloped country"
What bands are available to you?
JUST 2.4
5.7 and 5.8 is illegal, but everyone is using it at the moment for backhauling
We are using all non overlap channel for backhauling at the moment (6)
I heard 5.4 has lower transmit power, so maybe 5.7AP should be good for us.
Is it possible to build 5.7AP cluster where all the non overlap channel has been used by our backhaul?
Nope.
If you are using all the 5.7 spectrum for BH then you won’t have much success.
5.2 and 5.4 are lower power however if the spectrum is clear and legal to use you might want to go that way.
What is the status of 2.5Gz and 3.65GHz? Can you use those spectrum?
negative either…
I wonder howcome if I use all 57-58 spectrum for bh, and my 5.7ap cluster wont work well? supposed there is sync isnt it?
Or may be we must re engineered our bh spectrum again?
