Hola amigos del foro, me encuentro con problema. He actualizado algunos de los equipos a la version 8.1.4, y funcionan mucho mejor, pero tengo el problema al momento de gestuionarlos con Cacti, ya que cuando realizo un verbose query, para obtener las interfaces del radio, esta operación me reinicia el equipo Canopy y sin obtener completamente los datos. Aca les dejo una vista de lo que pasa.
+ Running data query [1].
+ Found type = ‘3’ [snmp query].
+ Found data query XML file at ‘/var/www/cacti/resource/snmp_queries/interface.xml’
+ XML file parsed ok.
+ Executing SNMP walk for list of indexes @ ‘.1.3.6.1.2.1.2.2.1.1’
+ Located input field ‘ifIndex’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.2.2.1.1’
+ Found item [ifIndex=‘1’] index: 1 [from value]
+ Found item [ifIndex=‘2’] index: 2 [from value]
+ Located input field ‘ifOperStatus’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.2.2.1.8’
+ Found item [ifOperStatus=‘Up’] index: 1 [from value]
+ Found item [ifOperStatus=‘Up’] index: 2 [from value]
+ Located input field ‘ifDescr’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.2.2.1.2’
+ Found item [ifDescr=‘Motorola 10/100 FEC’] index: 1 [from value]
+ Found item [ifDescr=‘Canopy MultiPoint’] index: 2 [from value]
+ Located input field ‘ifName’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.31.1.1.1.1’
+ Found item [ifName=‘1’] index: 255 [from value]
+ Located input field ‘ifAlias’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.31.1.1.1.18’
+ Located input field ‘ifType’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.2.2.1.3’
+ Found item [ifType=‘ethernetCsmacd(6)’] index: 1 [from value]
+ Found item [ifType=‘ethernetCsmacd(6)’] index: 2 [from value]
+ Located input field ‘ifSpeed’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.2.2.1.5’
+ Found item [ifSpeed=‘100000000’] index: 1 [from value]
+ Found item [ifSpeed=‘10000000’] index: 2 [from value]
+ Located input field ‘ifHwAddr’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.2.2.1.6’
+ Found item [ifHwAddr=‘00:0A:00:3E:F0:74:E6’] index: 1 [from value]
+ Found item [ifHwAddr=‘00:1A:00:3E:F0:74:E6’] index: 2 [from value]
+ Located input field ‘ifIP’ [walk]
+ Executing SNMP walk for data @ ‘.1.3.6.1.2.1.4.20.1.2’
+ Found data query XML file at '/var/www/cacti/resource/snmp_queries/interface.xml’
Despues que pasa esto, me sale
SNMP Information
SNMP error
