Problems accessing the IP of the recently reset Cambium cnPilot R190W device through the browser?
me preguntas es como puedo poner una ip estatica al router Cambium cnPilot R190W, lo resetie y ahor no puedo aceder a la configuración , alguien tiene alguna solucion llevo mas de dos dias queriendo acceder a la configuración
Translation:
My question is how can I put a static IP on the Cambium cnPilot R190W router? I reset it and now I can’t access the configuration. Does anyone have a solution? I’ve been trying to access the configuration for more than two days.
When you reset the router… you defaulted the router to its factory default settings.
Plug your computer (with your computer set up for DHCP) into one of the LAN connections on the router, then reboot the router - and then reboot your computer.
You computer should get an IP address via DHCP. Make sure the computer gets an IP address somewhere between 192.168.11.2 and 192.168.11.254
Ping your R190W router on 192.168.11.1 You should be getting good ping returns
With your browser, you should now be able to type 192.168.11.1 and get into the Login Page of the router.
The default Username and the Password for the router should be admin.
mi estimado realice todos los paso que me dijo, realice un ping al 192.168.11.1, el ping me da respuesta, pero cuando pongo en el navegador no me muestra la configuración, probé con otro navegadores el problema persiste que puedo hacer mas
Make sure you try to access the lo on page with both:
http and https
Make sure you try to access the logon page of your router with both:http and https
