Problems with color code / SM association
Hi, with the upgrade 14.1.1 for AP PMP450, we noticed a strange problem with SM PMP450.
The SM, after a normal reload, an AP Scan or disconnecting in autonomy, not back on the primary color code but in the secondary or tertiary.
It seems that the antenna no longer see the primary color code because in Tools->Ap evaluation the primary disappears.
If i wait the automatic rescan,
sometimes returns to see the primary color code, sometimes not.
Often disappear others color codes: if before we could see 9 AP, after a reboot can see 2; after an another reboot still can return to 9.
When the antenna is finally back on the primary color code, we see that the signal is strong, modulation ok.
Before the upgrade does not look like there was this problem but it certainly is from December 2015.
Here are some examples of antennas that have had the problem:
1 case) AP
Software Version :
CANOPY 14.1.2 (Build 4) AP-AES
Event log AP
02/01/2016 : 18:04:12 CET : :Time Set
02/01/2016 : 23:07:38 CET : :Invalid ACK discarded, VC: 37 0a003eb38722
01/02/2006 : 01:29:13 CET : :Time Set
SM:
Software Version :
CANOPY 14.1.1 SM-AES
System Event Log SM
02/02/2016 : 03:10:45 CET : :user=none; *System Log Cleared*;
02/02/2016 : 05:17:56 CET : :Error, bad input frequency: 110219017
02/02/2016 : 05:18:01 CET : :Error: Invalid frequency:8253864 for band:19
02/02/2016 : 05:34:59 CET : :Error invalid frequency: 1076041706
02/02/2016 : 05:34:59 CET : :Error: Calibration does not match frequency band:22, using first cal.
Antenna in Secondary Color code (3). This is our configuration for ever SM: Color code 1 ever 0
This is the table of AP Evaluation in Color code 3, Color code 2 (primary in screenshot) is missing:
AP List
AP Selection Method used: Power Level
Current entry index: 6 Session Status: REGISTERED (via Secondary Color Code 3)
Index: 6 Frequency: 5600.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a0-ea-f4 Region: Other
Beacon Receive Power: -66.5 (-69.0 V / -70.0 H) dBm Beacon Count: 15 FECEn: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 24892 feet MaxRange: 25 miles TxBER: 1 EBcast: 1
Session Count: 2 NoLUIDS: 0 OutOfRange: 0 AuthFail: 0 EncryptFail: 0 Rescan Req: 0 SMLimitReached: 0
NoVC's: 0 VCRsv/430smFail: 0 VCActFail: 0
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 3 BeaconVersion: 1 SectorUserCount: 16 SyncSrc: 1
NumULSlots: 68 NumDLSlots: 103 NumULContSlots: 6
WhiteSched: 0 ICC: 1 Authentication: Enabled
SM PPPoE: Supported
Frame Period:5 ms
Beacon Statistics
Unsupported Feature Beacon Received :     0
Unknown Feature Beacon Received :     0
Old Version Beacon Received :     0
Wrong Frequency Beacon Received :     0
Non Lite Beacon Received :     0
After a reboot, no changes.
After a AP rescan:
Index: 5 Frequency: 5600.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 24941 feet MaxRange: 25 miles TxBER: 1 EBcast: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 3 BeaconVersion: 1 SectorUserCount: 15 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Index: 6 Frequency: 5540.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a0-eb-14 Region: Other
Beacon Receive Power: -64.0 (-67.0 V / -67.0 H) dBm Beacon Count: 15 FECEn: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 2 BeaconVersion: 1 SectorUserCount: 28 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Link between AP with Color code 2 and SM have a good signal, but why it was disappear? Link Capacity Test with Color Code 2 (primary):
In Logs->SM auth->SM Authorization Log in bold the disconnections:
01/28/2016 : 18:33:05 CET : Event: SMSESFAIL, MsgType: SMVCERR, NewState: OOSERVICE, Flag 375
01/28/2016 : 18:35:06 CET : Event: SMSESACTIVATE, NewState: REGISTERING, Flag 0
01/28/2016 : 18:35:06 CET : Event: SMSESMSG, MsgType: SES_AAATMPACCESS, NewState: REGISTERING, Flag 20
01/28/2016 : 18:35:06 CET : Event: SMAUTHORMSG, NewState: REGISTERING, Flag 0
01/28/2016 : 18:35:05 CET : Event: SMAUTHENMSG, NewState: REGISTERING, Flag 0
01/28/2016 : 18:35:05 CET : Event: SMSESINS, NewState: REGISTERED, Flag 20
01/28/2016 : 18:35:05 CET : Event: SMAUTHORMSG, NewState: REGISTERED, Flag 0repeated 2 times
02/01/2016 : 11:22:34 CET : Event: SMSESFAIL, MsgType: SMVCERR, NewState: OOSERVICE, Flag 1275
02/01/2016 : 11:24:36 CET : Event: SMSESACTIVATE, NewState: REGISTERING, Flag 0
02/01/2016 : 11:24:36 CET : Event: SMSESMSG, MsgType: SES_AAATMPACCESS, NewState: REGISTERING, Flag 19
02/01/2016 : 11:24:36 CET : Event: SMAUTHORMSG, NewState: REGISTERING, Flag 0
02/01/2016 : 11:24:35 CET : Event: SMAUTHENMSG, NewState: REGISTERING, Flag 0
02/01/2016 : 11:24:35 CET : Event: SMSESINS, NewState: REGISTERED, Flag 19
02/01/2016 : 11:24:35 CET : Event: SMAUTHORMSG, NewState: REGISTERED, Flag 0repeated 2 times
In Logs->SM auth->Sm Session Log:
http://textuploader.com/573rn
What are the errors REGREQTOMAXERR and SMVCERR?
2) SM
Software Version :
AP List
After an AP Rescan:
AP List
Current entry index: 4 Session Status: REGISTERED (via Primary Color Code 5)
Index: 0 Frequency: 5495.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a0-67-fa Region: Other
Beacon Receive Power: -82.2 (-84.0 V / -87.0 H) dBm Beacon Count: 5 FECEn: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 0 feet MaxRange: 25 miles TxBER: 1 EBcast: 1
Session Count: 0 NoLUIDS: 0 OutOfRange: 0 AuthFail: 0 EncryptFail: 0 Rescan Req: 0 SMLimitReached: 0
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 6 BeaconVersion: 1 SectorUserCount: 8 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Index: 1 Frequency: 5550.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-b2-65-d2 Region: Other
Beacon Receive Power: -80.5 (-83.0 V / -84.0 H) dBm Beacon Count: 15 FECEn: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 0 feet MaxRange: 13 miles TxBER: 1 EBcast: 1
AP Gain: 22 dBm AP RcvT: -60 dBm SectorID: 0 Color Code: 103 BeaconVersion: 1 SectorUserCount: 3 SyncSrc: 1
NumULSlots: 16 NumDLSlots: 60 NumULContSlots: 4
WhiteSched: 0 ICC: 0 Authentication: Enabled
SM PPPoE: Supported
Frame Period:2.5 ms
Index: 2 Frequency: 5580.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a2-41-e9 Region: Other
Beacon Receive Power: -81.5 (-85.0 V / -84.0 H) dBm Beacon Count: 14 FECEn: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 4 BeaconVersion: 1 SectorUserCount: 8 SyncSrc: 1
NumULSlots: 27 NumDLSlots: 41 NumULContSlots: 6
SM PPPoE: Supported
Frame Period:2.5 ms
Index: 3 Frequency: 5630.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-b2-65-bb Region: Other
Beacon Receive Power: -79.9 (-82.0 V / -84.0 H) dBm Beacon Count: 10 FECEn: 1
AP Gain: 22 dBm AP RcvT: -60 dBm SectorID: 0 Color Code: 102 BeaconVersion: 1 SectorUserCount: 15 SyncSrc: 1
SM PPPoE: Supported
Frame Period:2.5 ms
Index: 4 Frequency: 5795.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a0-c6-71 Region: Other
Beacon Receive Power: -74.5 (-77.0 V / -78.0 H) dBm Beacon Count: 15 FECEn: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 36603 feet MaxRange: 25 miles TxBER: 1 EBcast: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 5 BeaconVersion: 1 SectorUserCount: 24 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Index: 5 Frequency: 5860.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-b2-f7-13 Region: Other
Beacon Receive Power: -87.0 (-90.0 V / -90.0 H) dBm Beacon Count: 8 FECEn: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 0 feet MaxRange: 15 miles TxBER: 1 EBcast: 0
AP Gain: 22 dBm AP RcvT: -58 dBm SectorID: 0 Color Code: 94 BeaconVersion: 1 SectorUserCount: 5 SyncSrc: 1
NumULSlots: 19 NumDLSlots: 57 NumULContSlots: 3
WhiteSched: 0 ICC: 0 Authentication: Disabled. SM configured to require authentication.
SM PPPoE: Supported
Frame Period:2.5 ms
Index: 6 Frequency: 5870.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-b2-0d-1b Region: Other
Beacon Receive Power: -84.8 (-86.0 V / -91.0 H) dBm Beacon Count: 5 FECEn: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 21 BeaconVersion: 1 SectorUserCount: 10 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Why there are two new AP (one of these is not even ours)?
This is our problem: antennas see sometimes and sometimes not APs, although very near. In this case, Ap with frequencies 5580 e 5550 are weak, but it is the same with signal -65
3)SM
Software Version :
CANOPY 13.4 SM-AES
AP:
Software Version :
CANOPY 14.1.1 AP-AES
Primary Color Code is 1, but after a reboot, disappear. After two AP Rescan, SM is come back in AP with Color Code 1.
I am the only one with this problem? Solutions? :(
Guido - Technician
Today another case:
AP97 with (primary) color code 7 - CANOPY 14.1.2 (Build 4) APL-AES
AP94 with (secondary) color code 4 - CANOPY 14.1.2 (Build 4) AP-AES
SM with primary color code 7 and secondary 4 - CANOPY 14.1.1 SM-AES
09:14 = hour of disconnection
(in order)
In AP97 (primary), Logs ->Ap Session:
AP Session Log
Session Dump for LUID 5 (->Sm with problem)
02/04/2016 : 08:38:50 CET : Event: SES_MSG, MsgType: PAREQ, NewState: IN SESSION, Flag 0
repeated 17 times
02/04/2016 : 09:14:27 CET : Event: OOS, MsgType: VCERR, NewState: IDLE, Flag 1361
In the SM, logs -> Sm sessions ->
02/04/2016 : 09:14:30 CET : Event: SMSESFAIL, MsgType: SMVCERR, NewState: OOSERVICE, Flag 1365
02/04/2016 : 09:18:44 CET : Event: SMSESACTIVATE, NewState: REGISTERING, Flag 0
02/04/2016 : 09:18:44 CET : Event: SMSESMSG, MsgType: SES_AAATMPACCESS, NewState: REGISTERING, Flag 19
02/04/2016 : 09:18:44 CET : Event: SMAUTHORMSG, NewState: REGISTERING, Flag 0
02/04/2016 : 09:18:44 CET : Event: SMAUTHENMSG, NewState: REGISTERING, Flag 0
02/04/2016 : 09:18:45 CET : Event: SMSESINS, NewState: REGISTERED, Flag 19
02/04/2016 : 09:18:45 CET : Event: SMAUTHORMSG, NewState: REGISTERED, Flag 0
repeated 2 times
In AP94(secondary), Logs ->
AP Session Log
Session Dump for LUID 27
02/04/2016 : 09:20:44 CET : Event: SES_MSG, MsgType: PAREQ, NewState: IN SESSION, Flag 0
repeated 18 times
 In SM:
SM Authentication Log
02/04/2016 : 09:14:30 CET : Event: AUTHEN_RESET, NewState: IDLE, Flag 0
02/04/2016 : 09:18:44 CET : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
02/04/2016 : 09:18:44 CET : Event: AUTHEN_EAPSTART, NewState: AUTHENTICATING, Flag 0
02/04/2016 : 09:18:45 CET : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
02/04/2016 : 09:14:30 CET : Event: AUTHOR_RESET, NewState: IDLE, Flag 0
02/04/2016 : 09:18:44 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: IDLE, Flag 0
02/04/2016 : 09:18:45 CET : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
02/04/2016 : 09:18:45 CET : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
02/04/2016 : 09:18:44 CET : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
02/04/2016 : 09:18:44 CET : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 126Antenna now in AP94 (secondary):
EAP Radius Log
02/04/2016 : 09:18:44 CET : Create EAP Session.
02/04/2016 : 09:18:44 CET : Restarted EAP Session.
02/04/2016 : 09:18:44 CET : FULL Restart EAP Session.
02/04/2016 : 09:18:45 CET : EAP SUCCESS For Session
02/04/2016 : 09:18:45 CET : Deleted EAP Session.
AP List
Current entry index: 1 Session Status: REGISTERED (via Secondary Color Code 4)
Index: 0 Frequency: 5715.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-b2-39-37 Region: Other
Beacon Receive Power: -84.5 (-86.0 V / -90.0 H) dBm Beacon Count: 15 FECEn: 1
AP Gain: 22 dBm AP RcvT: -60 dBm SectorID: 0 Color Code: 104 BeaconVersion: 1 SectorUserCount: 1 SyncSrc: 1
SM PPPoE: Supported
Frame Period:2.5 ms
Index: 1 Frequency: 5740.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a0-8a-a2 Region: Other
Beacon Receive Power: -67.2 (-72.0 V / -69.0 H) dBm Beacon Count: 5 FECEn: 1
Type: Multipoint Avail: 1 Age: 0 Lockout: 0 RegFail 0 Range: 46354 feet MaxRange: 25 miles TxBER: 1 EBcast: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 4 BeaconVersion: 1 SectorUserCount: 20 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Index: 3 Frequency: 5620.000 MHz   Channel Bandwidth: 20.0 MHz  Cyclic Prefix: 1/16
ESN: 0a-00-3e-a0-b0-10 Region: Other
Beacon Receive Power: -78.2 (-83.0 V / -80.0 H) dBm Beacon Count: 12 FECEn: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 3 BeaconVersion: 1 SectorUserCount: 12 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Beacon Receive Power: -83.5 (-87.0 V / -86.0 H) dBm Beacon Count: 15 FECEn: 1
AP Gain: 22 dBm AP RcvT: -63 dBm SectorID: 0 Color Code: 5 BeaconVersion: 1 SectorUserCount: 28 SyncSrc: 1
SM PPPoE: Supported
Frame Period:5 ms
Where is Color Code  7? The signal was -64.
In this AP94 with seconday Color Code -68.
Guido
Thank you for this detailed analysis, Guido!
We are currently investigating an issue with SMs switching back and forth between color codes and not showing APs in the AP Eval scan list.  I'll update here when we have more news.
-Al
One of our techs reported this problem yesterday.
Both SM and AP were on 14.1.1
The only information I have from it is from the AP session log dump:
03/03/2016 : 17:17:11 UTC : Event: SES_MSG, MsgType: PAREQ, NewState: IN SESSION, Flag 0
repeated 2 times
03/03/2016 : 17:22:59 UTC : Event: OOS, MsgType: VCERR, NewState: IDLE, Flag 250
03/03/2016 : 17:42:44 UTC : Event: REGREQ, NewState: REGISTERING, Flag 0
03/03/2016 : 17:42:44 UTC : Event: AUTHEN_SUC, NewState: IN SESSION, Flag 0
03/03/2016 : 17:42:44 UTC : Event: SEND_AUTHOR_MSG, NewState: IN SESSION, Flag 0
03/03/2016 : 17:42:44 UTC : Event: SES_MSG, MsgType: ESNQUERY, NewState: IN SESSION, Flag 0
03/03/2016 : 17:44:33 UTC : Event: OOS, MsgType: VCERR, NewState: IDLE, Flag 250
03/03/2016 : 18:06:10 UTC : Event: REGREQ, NewState: REGISTERING, Flag 0
03/03/2016 : 18:06:11 UTC : Event: OOS, MsgType: AUTHENFAIL, NewState: IDLE, Flag 0
Unfortunately the tech swapped out the SM in order to complete the installation so I have no further information currently.
The repacement SM is running 13.4
Once I get the SM back on the bench I can investigate further.
I could find no issue with the SM above and it was re-used on another site with no issues arising, however I did have the same problem on a new build site today.
Again it was 14.1.1 on AP and SM, Again the same error messages "Event: OOS, MsgType: VCERR, NewState: IDLE, Flag 180" and random disconnects / reg failures.
This time I found that the SM could see another AP with partially overlaping frequency.
Once I cleaned up the partial RF overlap the issue resolved.
Hi, our problem is under investigation and we are doing some tests with Cambium although the nature of the problem is not discovered yet. Even today, for example, we have restarted an antenna that had set the primary and secondary color code with good signals:: it's back operating in the secondary after 48 minutes ........
EDIT: new beta with fix http://community.cambiumnetworks.com/t5/PMP-Beta/Beta-Software-14-1-2-Build-17-for-PMP-PTP-450-and-PMP-PTP-450i/m-p/54771#M588
Under test, seems works.
Tomorrow intrusive test!
