It’s been quite a while since I installed a 450B SM so I may have done something wrong.
I have 2 SMs that I tried to install today. They both said CBRS Authorization failed. I was at 7.9 miles so I proceeded to located 1 block from the AP with clear LOS and got the same results.
I can find no meaningful (at least to me) logging information anywhere (SM, AP, or CnMaestro) and I noticed the SM logs are not preserved. Is there some special place to look? I’d like to be able to do some debug next time I go into the field.
This I got from the AP
Session Dump for LUID 5
07/17/2023 : 09:18:31 MST : Event: REGREQ, NewState: REGISTERING, Flag 0
07/17/2023 : 09:18:31 MST : Event: SEND_AUTHEN_MSG, NewState: REGISTERING, Flag 0
07/17/2023 : 09:18:31 MST : Event: OOS, MsgType: CBRS FAIL, NewState: IDLE, Flag 0
repeated 1 times
07/17/2023 : 09:44:41 MST : Event: REGREQ, NewState: REGISTERING, Flag 0
07/17/2023 : 09:44:41 MST : Event: SEND_AUTHEN_MSG, NewState: REGISTERING, Flag 0
07/17/2023 : 09:44:42 MST : Event: OOS, MsgType: CBRS FAIL, NewState: IDLE, Flag 0
repeated 1 times
07/17/2023 : 10:55:14 MST : Event: REGREQ, NewState: REGISTERING, Flag 0
07/17/2023 : 10:55:14 MST : Event: SEND_AUTHEN_MSG, NewState: REGISTERING, Flag 0
07/17/2023 : 10:55:15 MST : Event: OOS, MsgType: CBRS FAIL, NewState: IDLE, Flag 0
repeated 1 times
This is probably my issue
07/17/2023 : 09:18:31 MST : Initializing CBSD
07/17/2023 : 09:18:31 MST : Received code: [INVALID_DEVICE] error message: [Device not found or invalid device] from cnMaestro for SM Config Pull Request
07/17/2023 : 09:18:31 MST : Initiating CBSD registration
07/17/2023 : 09:18:31 MST : Sent Registration Request
07/17/2023 : 09:18:31 MST : Received Registration Response
07/17/2023 : 09:18:31 MST : CBSD Registration information clear sent
07/17/2023 : 09:18:31 MST : CBRS Registration pending due to missing information.
07/17/2023 : 09:18:31 MST : Error data received from SAS : ["installationParam"]
07/17/2023 : 09:18:31 MST : Registration not possible [Err: CBSD_RECV_REG_PENDING], so give up.
07/17/2023 : 09:44:41 MST : Received code: [INVALID_DEVICE] error message: [Device not found or invalid device] from cnMaestro for SM Config Pull Request
07/17/2023 : 09:44:41 MST : Initiating CBSD registration
07/17/2023 : 09:44:41 MST : Sent Registration Request
07/17/2023 : 09:44:42 MST : Received Registration Response
07/17/2023 : 09:44:42 MST : CBSD Registration information clear sent
07/17/2023 : 09:44:42 MST : CBRS Registration pending due to missing information.
07/17/2023 : 09:44:42 MST : Error data received from SAS : ["installationParam"]
07/17/2023 : 09:44:42 MST : Registration not possible [Err: CBSD_RECV_REG_PENDING], so give up.
07/17/2023 : 10:55:14 MST : Received code: [INVALID_DEVICE] error message: [Device not found or invalid device] from cnMaestro for SM Config Pull Request
07/17/2023 : 10:55:14 MST : Initiating CBSD registration
07/17/2023 : 10:55:14 MST : Sent Registration Request
07/17/2023 : 10:55:15 MST : Received Registration Response
07/17/2023 : 10:55:15 MST : CBSD Registration information clear sent
07/17/2023 : 10:55:15 MST : CBRS Registration pending due to missing information.
07/17/2023 : 10:55:15 MST : Error data received from SAS : ["installationParam"]
07/17/2023 : 10:55:15 MST : Registration not possible [Err: CBSD_RECV_REG_PENDING], so give up.
