Apparently v14 was released in the last day or so, and cnMaestro import now requires v14 and won't accept v13.
Anybody else having problems with v14?
I get an error about maxEIRP not being populated, but the sheet is protected and I can't populate it. And it is supposed to be an info only cell.
I tried just ignoring the error message but then I run into another problem when I click Import. It gets rejected saying User ID cannot be blank, but it isn't blank, in fact that field is automatically filled in by cnMaestro based on the account settings, you can't even edit that field.
This is stopping me from adding SMs, I assume it would also stop adding sectors. I guess I could try the non-spreadsheet method but that is very labor intensive.
