Please note. When upgrading to release 4.2.3 you must update the CanopyBoot to 3.0. The boot (block.bin) is NOT an optional upgrade. Your radio will become inaccessible if you do not upgrade the CanopyBoot to 3.0 as part of your 4.2.3 upgrade.
Please see our Knowledge Base at the following URL for more information:
http://www.canopywireless.com/kbase/ind … d=272&c=18
what if the solution if some one did it by mistake any solution to it as i i m facing this problem.
Kindly tell me the solution as soon as possible.
Regards
Saud hassan
If the product is still under warranty then you can contact your distributor and request an RMA.
