We have a PTP 650, the PSU port of the ODU is loose/faulty, can AUX be used as alternative for PSU? since AuX can power camera, i was just thinking that it has a direct connection between PSU and AUX power supply Pins..
There is no direct connection between the Main PSU port and the Aux port. The Main PSU port must be used for power input to the ODU. The Aux port can optionally be used for PoE output.
Unfortunately, it seems that repair or replacement is the only option here.
Is it the RJ 45 scket that's loose?
Thanks for the information Mark....Yes, the PSU socket is loose.. there's no nore option but to send it for repair..Thank you again
