Iwouldappreciate your review on my lab testing related to GPS TDD ePMP2000 PtMP with 3x ePMP1000 CPE.
From my testing it seems that there is throughput degradation with every additional CPE to sector.
Before I started I assumed there won't be any degradation more likely will be higher sector throughput due to 100Mbps Ethernet port on ePMP1000 CPE.
I attached here system drawing with all setting information.
Every CPE reached maximum air performance MCS15/MCS15 100% link quality
I decided to test only with packet size 1024 & 1522 Bytes because of ePMP PPS limitation (~15K) results in poor performance (maximum throughput is very low ) with small packet sizes.
Have you also experienced sector throughput degradation with every additional CPE?
What is your registered link distances ? These kinds of test are best when letting them do what they do naturally, no coax.
We have APs in the wild with 70 cpes attached and moving 120 Mbps downlink during peak, still have a little room left in the frame. I’ve never taken the time to measure with ap cpes completely active.
Another good test for you to do, cause one CPE to have awful link conditions and obverse those effects. And do that with competitive equipment.
That’s when you’ll see the epmp shine.
As a whole system (multiple towers and hundreds of cpes), I haven’t seen anything in the epmp price range touch it.
