Hi cambium people.
This is teh first time I'm gonna deploy a ptp650 solution and wanna make sure every single detail goes right.
1. I need Tdm OIP, 1 E1
2. I need at least 20 mbps of data over a 100km link .(LoS perfect)
What should I buy?
ptp650L? or ptp650? (Already have 2 3ft dishes).
Should I buy any aditional licese ?
2 IDU's?
2 Ac to dc cambium injectors?
2 surge and lightning Arresters?
Any thing else?
I would really appreciate some advice.
DImas
RayS
(RayS)
2
Hi. I am glad to hear that you are looking to build a long link. You will want to start by downloading the free LINKPlanner software to help you plan the details. You can find LINKPlanner at http://www.cambiumnetworks.com/products/software-tools/linkplanner/
You may also want to check out our latest LINKPlanner webinar HERE.
Thank you very much for pointing out link planner, you are right , every thing needed is there.
I'll post some pics when the project is done.
Cheers.
