Hello. I have some troubles with eth speed.
1st site:
I have there:
PTP 650 - 25mt cable that goes through a giga eth protector, and runs fine at 1000/full.
PTP110 - 25 mt cable that goes through a giga eth protector, and runs at 1000 for a few seconds, then works at 1000/full.
I have removed the protector and put the cable right into the POE, and runs at 100/full.
The switch is a HP 2810-24G with latest firmware.
I have tried to use a multiple giga poe injector gigabit, 24V 0,65Amp max, fixed at 100/full.
2nd site:
PTP 650 - 10mt cable direct to the POE, 100/full (then to a Toughswitch Ubiquiti, and a HP 1810-8G)
PTP 110 - 10mt cable direct to the Toughswitch Ubiquiti, 1000/full
3th site:
PTP 110 - 55mt cable direct onto a Ubiquiti POE 50V 1.2Amp - 1000/full - to switch HP 2810-24G
As you can see, in 2nd and in 1st site I have troubles with network speed.
The cables are all identical Cat 5E FTP maxcable external UV rated (not CCA!!!).
Opened ticket with cambiu, #SC21415
1st site:
I have there:
2nd site:
3th site:
We will make sure support works with you on this but in the meantime, could you clarify a few things?
Your problem is with the Force 110 PTP not getting 1000full speeds, correct?
The force 110 PTP is a 802.3af device - have you tried connecting it to the power supply that it came with?
Is the HP switch or the Ubnt tough switch a PoE device?
Hello
As I wrote in the previous post, I tried with:
Standard POE 30V 0,5Amp shipped with the unit.
UBIQUITI 50V 1.2Amp Giga POE (Airfiber model)
1U Rack POE Gigabit 24V 0,5Amp (third-party).
The problem is that I am not able to get a stable 1000/full.
The HP2824 and the UBNT Toughswitch arenot used as POE devices, they are used as plain switches.
Just today, I installed a net Force 110 PTP that negotiated at 1000/full. After some tests, it had heavy packet loss. I set it in the switch to "auto 10-100 speed", and it negotiated at 100/full with no loss.
I think there is a problem in the eth chipset on the Force 110 PTP units.
